Solved use listen features for calls generated by extensions
fvelo
Hi, we have a client who is trying to implement this feature, and so far we can do it for incoming calls that go through a queue, but the client is interested in doing listen and whisper to callers that generate calls from their extensions without going through a queue, we have the permissions set to do this but are only able to do it on incoming calls that go through a queue, is it possible to do listen and whisper for all possible calls from an extension?
thanks beforehand.
Francisco Velo
It should be possible if the agent has "Show calls to group", the manager has "Can see group calls" and manager also has "Can bargein/listen/whisper".
Also, since you're talking about outgoing calls, the extension wanting to use the "listen" function would also have to be in the same group as the extension making the call.
we, just managed to test it and it is working without issues, thanks a ton for the tips!
Reactions: VasilisV_3CX
Great to hear that it works @fvelo! Feel free to open a new thread if you require anything else!
Mr_IT
