User unable to receive calls on android
Adrian-Blue
Gold Partner
We have a user that is unable to receive calls on the 3CX app for Android. The phone is a Samsung Galaxy S23. The device is up to date with Android updates. Push notifications are enabled. The only way to get the app to work is to go into the app settings on the phone and delete all the data and clear the cache. This seems to only be a temporary fix as the issue returns after a while. We have not had any other users report issue. This user has been using this device for a while and it was working fine. The issue only started a couple of weeks ago. Any help would be appreciated.
@Adrian-Blue version of Android client and PBX version
Mine is a Samsung S22 Android 14 UI 6.1 with 3CX Client 20.0.0.44 and PBX V 18 Upg 9 Build 31 and suddenly i'm able to call but i don't receive calls and the presence upper dot remains grey, cannot list contacts, and recent calls. All firewall ports are the same. Any ideas?
PBX: 3CX V18
Client device: POCO X3 (Example)
Android: 12
3CX App ver: 20.0.0.44
@ThomB_3CX
Kindly note that everyone in a particular organization (Android and iOS users) are having the incoming call issue on the 3CX App, outgoing is working though.
In terms of NAT Rules on the Firewall, everything was set as per https://www.3cx.com/docs/manual/firewall-router-configuration/
Can you please help me on this issue.
Thanks in advance.
Regards
Vinesh
/dev/simon
