Using two ISPs. One is okay, other has delays and incomplete target route?
David Fowler
Forum User
We have two ISPs (dual WAN) that we use within the office. Connecting to a hosted 3CX server with STUN. The slower ISP handles calls in a timely manner (but vanishes since last upgrade, subject for another time), the faster ISP adds 10-15 second delay to calls.
Sticky particulars:
3CX 16.0.3.676
Debian 9 at OVH
Yealink T48S(15), T40G(1), CP960(1)
All set to STUN
Trunk is VoxTeleSys (nice people) uses registration/account based
Passes Firewall check
No custom telephone templates
While scouring the logs with the log reader, I did find this interesting tidbit?
On the working ISP, the target route for CM503004 and onward has a target route twice as long as the annoying ISP.
Good: T:Extn: ext#@[Dev:sip:ext#@ispgoodip:47870,Dev:sip:ext#@127.0.0.1:5483;rinstance=hexgobbledigook]
Delayed: T:Extn: ext#@[Dev:sip:ext#@ispdelayedip:28868]
The second sequence with the localhost and rinstance is missing? Is this a clue or a red herring?
Cell phone apps don't appear to care which ISP is used, they just work. I don't mind barking at the ISP, but I would like to be coherent? Or I can kick myself if it is something on my end.
Sticky particulars:
3CX 16.0.3.676
Debian 9 at OVH
All set to STUN
Does this only happens with deskphones? If so, have you checked your firewall ports forwarding? You are using 3 phones in STUN which is pretty much the limit (unless they are not on the same network).
Also, I'd run a packet capture from 3CX on both scenarios to compare what steps is slowing the call down.
Hi David,
Regarding the dual WAN, are you using one at a time or can a phone connect to the PBX from either? How is NATting handled?
Since you have more than a handful of phones, I would suggest to consider installing an SBC to bypass any firewall related issues and perhaps some ISP based issues too (depending on the case).
Wecare_ITA
