v16 Firewall in Dashboard
Shane Farmer
I haven't had time to run the firewall checker during business hours, yet, but I checked the port list and it still showed v14 and v15. Is there a different list for v16?
It shows a red exclamation icon in my dashboard since upgrading from v15.5SP6 to v16 last night. So far things are fine. I tested the Android app from outside and other things appear OK.
I disable an inbound rule blocking certain IP ranges that I have blacklisted over the last few years. When I disable it, the first set of test passed, but Ports 9200 and up or so show "full cone test failed".
Ideas? What IPs need to be allowed to run Firewall Checker?
The firewall checker is a tool, not a requirement. If everything is working for you, leave it alone. If you want the green seal of approval, disable your blocking rules, run the checker, re-enable them. As long as your SIP trunks and endpoints can talk to 3CX nothing else matters.
Thanks for the info. I do like to have everything green, lol. I will just leave it for now and play with it over the summer when I can afford to have phones down a while.
Green is good
fransisco
