V18: App - change switchboard font size
AGeleijns
New User
I use the switchboard feature of the app to monitor the incoming calls for the agents.
To do this i have the app open on my screen. But then switchboard font is very large at the moment probably for TV viewing.
Is it possible to set the fontsize smaller or to make it a setting?
I can suggest a workaround:
1. Open your webclient on the screen you want to use ie. TV within Chrome
2. Login to the 3CX webclient in your browser and go to "Panel"
3. From the drop down menu on the right choose the Wallboard of course (you can optionally use the pop out arrow)
4. And now you can use your browser's zoom feature to change the font size (usually Ctrl+ or Ctrl-)
5. Optionally, you can press F11 to go full screen
sus.edv
