Solved V18 Shared screen shown as webcam video
HExSM
Forum User
If we use the screen sharing feature, the screen seems to be used as webcam video.
We are using 3CX version 18.0.232 Enterprise.
The Browser was Google Chrome version 94.0.4606.81.
Hi @HExSM,
Can you join with your audio and video enabled from the launch pad, and let me know if sharing still produces the same issue? We are aware that there is an issue, and we're working on a fix for this.
Same here. I use it EVERY day, multiple times a day. I big problem for me.
@VasilisV_3CX,
I can confirm the behaviour. If I start with audio and video enabled, the screen sharing works fine. If I start with audio enabled and video disabled, it uses the shared screen as webcam video.
Hi @VoIPTools and @HExSM,
In the interim until this issue has been resolved, you'll need to join the meeting with the audio and video enabled from the launch pad (where you enter your name and such) in order to have it share correctly.
As I mentioned, this is a known issue and is being investigated.
Good evening everyone,
I was able to replecate this issue and identify a possible fix. in your google chrome site settings, please check if the "your device use" setting is set to allow, if it is set to ask or block I noticed that the screen sharing breaks.
Graham Robertson
