V18 Update 1 Beta 2: Now with Yealink Headset Integrations
Sennheiser is the headset integration provided as part of Standard license. As a result what you get is the correct list based on your active license.
thanks - was not aware that headset integration was restricted to license level - is this something new?
No it is not new, think EPOS | Sennheiser integration came with v15.5, or beginning of v16, in standard, and the other (Plantronics / Jabra) was only offered in PRO/ENT (for the WEBClient Integration)
Any news on when the 3CX support/ticket system will be introduced, which SP can we expect it? Excited to test it out.
license version comparison
Good point, I pulled up the 3CX comparison page and all 3 have "headset integration" checked.
Hey Guys,
Question, as far as i can see this wont work with the wh66 and 3cx.
I need a solution that allows me to see on the headset's dock who is calling.
Therefore I tried the wh66 but that was an epic fail.
Is there a headset with a dock that allows me to see caller information.
For who want to know why i dont watch my screen when someone is calling.
me and our customers all work in a RDS, so we have the webclient open communicating with the local 3cx client.
Are we able to minimise on system start yet on this version?
I'm on 18.5.28 and it's still not an option.
Hi the dial from the pad of yealink w66 is not working after upgrade to 18.0.302. Any idea? It was working well before.
The dial from the pad is not meant to work (...at least not yet). The integration for the time being covers the control buttons for answer/hangup/etc...
Hello @sofnisys ,
Due to adjustments that we did with the headset integration (based on Yealink guidelines) to support MS Teams answering client priority, the dial from Yealink pad will not be supported for now.
This is something that Yealink is aware off. Unfortunately it is not something that we control.
Hi Nick, I confirm you It is working with version 18.5.28 after update it stopped working. I can reproduce it
The new version 18.7.7 is not working
Reactions: NickD_3CX
Indeed is a feature that we would like also to have as part of the headset integration.
You can reach Yealink Support Team (https://support.yealink.com/) to check the status in regards to this issues.
From our end we are pushing Yealink team to support it in future updates, but is important also to have pressure from the customers perspective.
Yep all ready done ;)
Message from Yealink:
For your requirement, I checked with our PM team and they told me that we are doing dial pad integration with 3CX now, the expected release time is Q1 2022.
I will feed you back at once if the new one is released.
Please wait patiently.;)
Reactions: accentlogic
Hello @sofnisys ,
Indeed this is the target date that we have also from Yealink
Jeremy Hofex
