V20 Call Forwarding to Queue
mbau
In the call forwarding till V18 was possible to select an queue as a target. In V20 this is no longer possible, but we need this.
How can I do this?
In version 20 you will need to select "System Extension", not "Extension"
If you select this and you cannot see your queue(s)
then you need to go into your options of the system and allow the viewing of system extensions
Just remove the highlighted option and your queues will be visible now.
Reactions: bitn2
Thank you very much, that helped :).
ARTipsadmin
