V20 - Change FQDN
maxihoster
I dont' found anyway to change my fqdn for my 3cx install!
The problem is when creating a backup with V20 we can't select option to create backup without license and FQDN information!
Trying to release FQDN into my 3cx portal console and reinstall a new 3cx importing backup but the license and fqdn are include into backup so the problem persist.
Someone have a solution for that?
Regards
Same issue here
In version 20, you can not take a backup without the license key and FQDN included within the backup.
what about the BackupCmd command line? is this still available? as there was an option where you can include or exclude FQDN and license
Yes the BackupCmd still appears to work on V20, I assume just need to backup everything except FQDN and LIC
eg 3CXBackupCmd --file=partial_pbx_backup.zip --options=CH,PROMPTS,FW,REC,VM,MIN
see https://www.3cx.com/docs/backup-restore-command-line/
for more details
Is this the new configuration or is the ability to take a backup without license key and FQDN coming back?
for more details
Will this work for the Hosted by 3CX instances as well? I can't check this since the command line console was removed in V20.
No, you dont have access to ssh.
Reactions: IrinaP_3CX
Charles, what will be the new method of changing the FQDN?
We have the same situation. We need to migrate to a new license/fqdn.
It seems like the license is still in the backup file when using 3CXBackupCmd.
I am stuck here as well. I can't change the FQDN. Is there any update? Did anyone manage to update fqdn?
Hi Charles, So what is the best practice if you were to change the fqdn in V20?
Hi, for this, you will need to install a new system from scratch without restoring a backup.
Will this change in the future? Or is the new way to do reinstalls without restore to change FQDN?
We don't have any information on this changing in the future.
Aside from mergers/buyouts, it would prevent someone from changing from a 3CX FQDN to a custom FQDN, or vice versa, without starting over.
Do I understand it correctly that you can't change the FQDN without doing a complete reinstall from scratch, in an on-premise installation?
So, for example, switching from sip.example.com to pbx.example.com requires me to do a fresh install and configure *everything* from scratch?
There must be another way, that's ridiculous.
we have the same issue, we need to change only the FQDN for our customer, as we had a location in the fqdn name and now he wants to use the system global.
You must re install the system to change the FQDN. If on version 20 then a full new instil is required. Switching the current machine and after releasing the current FQDN from the subscription.
how can I do the reinstall with a new FQDN? if I go to the portal, i only get the FQDN predefined and I cant select a new FQDN.
ARKC
