Solved V20 install SBC on Raspberry Pi
RDWild
The SBC install is failing on a Raspberry Pi with a V20 install. Getting the following:
2024-05-21 18:56:14 (23.7 MB/s) - written to stdout [26298/26298]
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
connecting https://xxxx.xx.3cx.us
Ign:1 http://downloads-global.3cx.com/downloads/debian bullseye InRelease
Err:2 http://downloads-global.3cx.com/downloads/debian bullseye Release
404 Not Found [IP: 104.18.40.127 80]
Reading package lists... Done
E: The repository 'http://downloads-global.3cx.com/downloads/debian bullseye Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
error: Cannot install the 3cxsbc package
admin@GBSBC:~ $
Yes, that is the guide I followed.
You have used the Raspbian image?
Yes, there may be something wrong with this Raspberry Pi though. I done these before, this one behaves very oddly.
This has been tested several time and there is no issue.
Maybe something related with network configuration?
I have actually used the exact same setup before with no issue. I haven't had a chance to test further, but this install of Raspbian or the hardware seems to be borked. I can no longer launch Chromium.
Launch chromium? the Pi image used doesnt have a gui.
Also you are trying to install Debian11 directly.
Refer to the previous reply with the guideline and use the Raspbian image and make another attempt:
It's all taken care of. Several times in the past, I used a Canakit raspberry pi with NOOBS, and installed an OS with a GUI. For whatever reason, that seems to be no longer working. I installed the raspbian image, and all is good.
Glad to know this is resolved ;)
sambannoura
