V20 U10 AI Customer Service Agent is the 10 second silence timer configurable?
JamesSchubert
Platinum Partner
We are testing the new AI Customer Service Agent in V20 Update 10 for first-line technical support and have found that the agent checks on the caller after 10 seconds of silence.
Is this timer configurable, or is the 10-second value currently fixed in AI 1.6.10?
Environment
3CX V20 Update 10 – 20.0.10.1277
3CX AI – 1.6.10
Agent Type: Customer Service
OpenAI Realtime: gpt-realtime-1.5
Voice: Marin
Use case: Level 0 / Level 1 technical support before human handoff
Problem
When the AI gives the caller a troubleshooting step and the caller needs time to complete it, 3CX checks on the caller after exactly 10 seconds.
Verbose 3CXAI.log shows:
Silence check ACTIVE
Silence timer armed: 10s
Exactly 10 seconds later:
silence timeout: counter 1
3CX then queues:
SayStep
text="Check if the caller is still there."
We have reproduced this consistently.
For example, one test shows the timer armed at 14:24:17.614 and the silence timeout at 14:24:27.615.
Another test shows the same behaviour from 14:19:58.937 to 14:20:08.938.
Why this is a problem
For a Customer Service Agent being used for first-line support, 10 seconds is too short for many normal troubleshooting operations, for example:
  • restarting a system
  • restarting a connected device
  • restarting an application
  • checking a printer
  • moving to another workstation
  • waiting for equipment to reconnect
The repeated check-ins can interrupt the caller while they are carrying out the requested troubleshooting and make the interaction feel unnecessarily rushed. After three or four check-ins, it can also become quite annoying for the caller.
Requested improvement
Could the silence/check-in timer please be made configurable per AI Agent?
Ideally:
  • configurable timeout, for example 10 / 20 / 30 / 60 seconds
  • ability to disable the check-in
  • or preferably an agentic mechanism that lets the AI temporarily suspend the silence timer when it has explicitly told the caller to perform a task and wait
For technical support use, I would probably configure this to around 30–60 seconds.
This 10-second timer is currently fixed. However, you could post it in the correct Ideas forum category for consideration.
Solution
