v20 update 1 - macs: warnings.xapi.invalid
Senõr Engineer
Platinum Partner
Have updated our 3CX self hosted cloud PBX to V20 update 1 to verify the process for roll out to customer instances and now get the following error when clicking to the users tab.
Can now no longer get to the users. Has this been reported elsewhere or can anyone shed any light on what is going on?
Cloud instance running on DigitalOcean.
So after some digging I have found the cause of this in that it appears that a voicemail greeting for a specific extension had gotten "lost" somewhere between the v18 to v20 and update 1 changes.
It was still referenced in the user but when trying to save it, it threw and error to say the greeting didn't exist. I found it by using the explicit edit URL for each user and then found the red "asterisk of something missing" for the Voicemail tab on one particular user.
After setting it back to the default greeting and saving it the users list sprang back to life! I then re-uploaded the "missing" greeting and re-checked it.
So I would suggest to all to add to the pre-post checks of:
  • Unique email addresses
  • Department/group mapping
  • 3CXtalk link name
  • etc. etc.
Also check the Voicemail tab for each user post initial v20 upgrade to ensure any custom voicemail greetings are actually there and if not re-add them.
Interesting how this problem did not manifest itself on the initial v18 to v20 upgrade - but fixed now and another check for the upcoming rollout!
tdzski5
