V20 Update 10 Alpha: MCP, AI Server & More Admin Control
Some really cool stuff here, and looking forward to getting to grips with the new features!
Has there been a change to call flow scripting? I ask as a script that works with CRM integration, that currently works fine in U9, is failing to start in U10 with the error "Autofac.Core.DependencyResolutionException: An exception was thrown while activating CallFlow.CFD.CRMLookupComponent.". More than happy to provide more detail if needed.
For the MCP client is there any future scope to include configuration endpoints?
Very nice update. Can't wait to test the MCP features. You guys are killing it!
I have one question about the Caller ID selection. I read this is only for users that have multiple DDI's assigned to them. We have customers with muli-queue agents who need to change their caller ID depending on the departpment they use for that call. The DDI's are assigned to their queues and not the users themselves. It would be awsome if they could select Queue assigned DDI's as well. At this moment we use multiple outbound rules and prefixes to handle this.
Thanks.
This is a very nice update indeed!
The ability to select the outgoing DID is an option we have been waiting for for a long time. Primarily because we previously worked with systems where this was possible. But indeed, being able to select DIDs from the queues you are currently active in would be the best option. Especially for smaller environments where someone can then call back from the general DID or, for example, the support queue DID.
Hey everyone- Great update. Really looking forward to a lot of these features. I am running into two issues with the new alpha update. Is anybody else seeing something similar?
1. My AI Agents are no longer answering. I have tried on both realtime1.5 and realtime2.0 and the calls just hang up immediately. Our agents were working prior to the update.
2. I created a new AI Transcription server and it shows successfully connected. However calls seem to get stuck "in queue". Screenshot below:
In event log i see the following occurring a few different times.
Error409607/30/2026 1:57 PMAI BridgeInternal Server Error
UPDATE:
Agents answer internal calls. They do not answer external calls. A call into an agent triggers the AI Bridge error above.
I'm having the same issue but it's with both internal and external calls to agents. I've tried setting up new agents from scratch too but am getting the same AI Bridge internal server error. Were you able to get this one resolved at all?
Thanks. Found one I didn't expect, but they have some dummy extensions and I bet they can use the new queue escalation algorithms.
Nick-
Are you still having the issue? I believe this ended up being a problem on the Open AI side and has been resolved for me.
Nick-
I still am! I'm working with 3CX support on it but so far no luck. It does look to be an OpenAI issue from the logs.
Thanks.
Same request here. DDI's are assigned to Department and routed to CQ's. The CQ members from different CQ's use outbound rules with corresponding prefix and outbound caller ID. It would be great if they can select the outbound rule instead of remembering the prefix for that rule.
SMS works this way (a number assigned to a queue is usable for outbound messages of queue members), so hopefully this is an easy change.
:D great updates thanks!
Undockable Dial pad and granular user permisions to reporting node is AWESOME.
One request on the dial pad, when undocked, can you add the BLF hide/unhide menu. As it is, need to redock it, toggle the blf, then undock again to show the blf panel un the undocked dialer.
This is a massive step forward for 3CX.
Native MCP support, the standalone 3CX AI Server, programmable voice applications, and greater administrative control are not simply new features, they are transforming 3CX into a much more flexible and enterprise ready communications platform.
Instead of forcing customers to adapt their operations to a fixed system, these capabilities will allow us to build around their actual business requirements.
We are genuinely excited to start testing these features and developing new solutions for our clients.
Shukran to Nick and the entire 3CX team. Update 10 looks like a major milestone, and we cannot wait to see what we can build with it.
Thank you so much for the heads up! Much appreciated.
And thank you for all the other positive comments from everyone. We have one more nice improvement coming for update 10 after our summer break!
I really love the new selective DID feature for outbound calls. This will be a huge benefit for many users.
As a possible enhancement, it would be great if outbound caller IDs could also be selected from the department's configured outbound rules.
Many employees work across multiple departments or roles and regularly switch between them during the week. In these scenarios, users often don't have a dedicated DID per role because the numbers are typically assigned to queues rather than individuals. Allowing users to select a department number directly would be a major usability improvement and would eliminate the need to dial prefixes before every outbound call.
It's hard not to get excited about the future when messages like these start appearing.
Excited to share some of the stuff we are working on. These are screenshots from a demo we have created to show customers and developers who want to partner with us what is capable. This is based off an internal tool we created that does essentially the same thing, just with IT and not Roosters. :)
Pulls orders, service tickets, categorizes the call, creates a summary after the call that gets inserted into the ticket automatically and provides for a single pane of glass that aggregates only the data the agent would need to handle the call.
There is a tremendous amount of potential out there to provide SMB with obtainable call center tools that, in the past, were only affordable by large enterprise.
I have a question about the feature: "Users with multiple assigned DIDs can now choose which number to use when placing an outbound call from supported 3CX Apps". Users usually need to make outbound calls on behalf of queue assigned numbers (like the helpdesk number or similar), not the ones that are assigned to the user. Was this also considered?
MCP Question: When connecting to 3cx hosted servers, we are able to query the event logs to get summary events. But on a Windows on-prem install, we are able to connect to the MCP, but there is no exposure to the log files. The version build is the same and the AI is the same version. The only difference between the on-prem and the hosted is one is on-prem is 8 sim calls and the hosted in 16 sim calls.
Hi @businesstechconsultants ,
Quick questions:
In both cases the extension authorizing the MCP connection was of the same level?
Do the machines have Admin Console IP restrictions? If yes, the option to bypass them was selected during authorization?
Quick questions:
Yes, the Admin Console IP restriction was on and I did check the bypass on the authentication. To test further, I turned off the console restriction. Removed the connector in chatgpt and then reconnected. This time the system is now access the full system. I did add the console restriction back and the connector is still working.
One other interesting issue, I asked the connector to blacklist and ip, it failed the first time, because it sent the command Block instead of Deny. But I told it to block the IP using Deny, it said the command still failed. So I went into the system and manually added the IP, but it says the IP is already in the blacklist, but it does not display on the blacklist screen. But if i issue it to blacklist another ip address and specifically request it to use Deny the IP is blacklisted. I was able to also remove the blacklisted IP. Just a few bits of information.
We have just setup the Multi-Tenant 3CX AI Transcription Server on Update 10, very excited to roll this out. Worked well on our tenant.
However, on Update 10 Alpha, it looks like it restricts using 3CX Transcription to AI 16SC+ licenses, all the other AI Transcription options don't have this requirement. I think it would be good to follow along the existing PRO = Voicemail and AI = Recording Transcription/Summary.
Let us know team!
GenAdmin
