- Joined
- Jun 20, 2018
- Messages
- 4,424
- Reaction score
- 2,153
I get it. I suspect it’s all “in flux” right now as they’re still adding things to RC3. Ultimately it would be good to have a list before v18 is no longer supported…or better yet everything included.That is not complete, for example, in v20 we cannot forward to extension SP1
The current upgrade script does not allow updates if the specs don't meet requirements.Will this be an enforced requirement of the platform by Release 1 or the strong recommendation?
https://www.3cx.com/community/threads/3cx-v20-where-is-rights-option.123688/#post-582932Hi, if I remember correctly, v20 would bring multiple phonebooks (phonebook for each Department).
I don't see this yet in the current v20 build, no mention aswell in the "will be added later"-list.
Any information about this available?
Hi Nicholas,
I'm affraid that all of the english ones are now also full. Are you planning to add some more in the future based on the huge demand?
Yes i see this as a very important thing too! Because we have many customers each with a lot of staff member that are using the Electron Desktop App V18. To install the new App by the staff member will not work and produce a lot of trouble.I appreciate your feedback, and it seems like you have a good memory. ^^
Deploying the application with MAC address imports requires a significant amount of upfront work.
I hope you will consider mass deploy mechanisms for Windows Store apps need to function before discontinuing the connection of the 3CX Desktop App.
But be in mind that many customers dont use Azure or 365 ;-)Could the Windows app use SSO via O365 to login and provision itself? Assuming the user is logged in to their AzureAD account.
See the bottom of https://www.3cx.com/blog/releases/v20-upgrade-checklist-faq/.do you know roughly how long we'd have until v18 was no longer supported
Ah yes, appears i missed that part. Cheers SteveSee the bottom of https://www.3cx.com/blog/releases/v20-upgrade-checklist-faq/.
Hi does anyone know if the 3CX V20 will also connect to SBC V18 devices?How about the SBC Controller V18.1.36 ?
Will they reconnect and work after upgrading to V20?
Many Regards and a happy new year!![]()
Yes, 3CX SBC will continue to work once the system is updated to version 20.Hi does anyone know if the 3CX V20 will also connect to SBC V18 devices?
Also other way worksHi does anyone know if the 3CX V20 will also connect to SBC V18 devices?
That sounds very good, thanks! The goal is to get a smoothless crossing to V20 without breaks with the telephonyAlso other way works
v20 SBC on v18 PBX... for fresh installations you can start with this avoid another system that needs an OS update
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
