Version 18 Update 6 Simplified. Modernized.
Hm, than try to uncheck the Option and activate it again, maybe that helps.
Bye
Timm
Hello Timm,
No joy :(
Also from the contacts page i`m not seeing the "PBX name" you have.
I only have the options "All contacts" or "Personal contacts":
To rule out any permissions i`ve made myself system owner:
Still no joy :(
OK, as an Systemowner id should work, because i'm a Systemowner too, and it will work, you sure you use the right Extension on the Webclient?
Lock out and lock in again.
Update: Which Version of 3CX you use? In U7alpha, i don't see either the Companybook.
Bye
Timm
Hello Timm,
I`m sure it`s the right extension.
I`ve logged out and logged in again no joy ( My colleagues have the same issue ).
I`m on 18.0 Update 6 (Build 908).
Hello Timm,
So please check your MCM Mode status, it should be 0, maybe thats why.
The MCM Mode you can change in the System Parameters. You have to search there for MCM.
Bye
Timm
Reactions: jed
Hello Timm,
Ah, That solves that indeed. Thanks!
Then there is still no option to add the number directly to the Company Phonebook.
But this is also the case on you`re end. So this is probably something that needs to be reported and requires 3CX to fix?
You mean that the default way is the Company Phonebook and not the Private one?
So the checkbox should be normally on?
Bye
Timm
I checked on multiple systems with a system owner account and the option is always there:
This is true when adding a Contact from the Call log or directly from Contacts.
Reactions: jed
Hi All,
Thanks for all of you`re time!
It was the combination of the MCM setting.
And after that remove the right and re-assign the right again.
Thanks for the screenshots! That made me check other installations and then i noticed it was just this installation.
sameage
