Video Calls Over Bridge Connection
caldwell
I have a working bridge between two systems (each are V20, latest beta as of today). When I try to add video to the call from the Master, the phone says, "The other end is not available."
If I try to add video from a Slave system device, the system never does anything in the App. In a web browser using that dialer, it flickers the LOCAL video for a second and then drops that. The remote phone at the Master never sees anything happen.
In the past, threads from 2016 (!) said: "With that being said video should work between bridges given that you enable the Supports re-invites, support 'Replaces' options in the advanced settings on both sides of the bridge."
That option doesn't exist anywhere in the Advanced tab of the Bridge settings on Master or Slave. What is the trick to getting video working over bridge connections currently?
abdullah.alshehri@rewaa
