Solved VLAN on PC Port
Alphabetic
3CX MVP
Hi all,
Ive got a Yealink T54W running supported template and FW as of todays date.
I've enabled VLAN from 3CX but it has not updated on the phone - am i doing something wrong?
I have factory reset the phone and rebooted to no avail.
Hi @kieferschild
I tried one now on V18 Update 3 + FW 96.86.0.63 and latest available official templates and then hit reprovision:
Confirm the setting was saved under the extension?
Are there two T54W phone entries on the extension perhaps?
Yes under ext settings.
No, just one phone.
I tried 7 and 7 to no avail.
Phone is on an SBC.
18.0 U3 B450
Check what 3CX is sending to ensure it is contained in the config according to what you selected in the extension settings:
1. Select phone and press +CONFIG
2. Click inside the test window and Ctrl+F for vlan.pc_port_enable
Ah F sake..
I just realised I've got 2 phones provisioned to my ext, didnt realise I was provisioning the wrong one.
Its working now xD
Reactions: JohnS_3CX
No i did see it, there is only one T54W phone but once upon a time I must have set up a T42S to test and never removed it from my ext.
No worries, glad its all sorted!
Finatra.us
