Solved VM Transcription
amir_
We are running
Product Enterprise Annual
Version Number 16.0.9
I've followed this doc:
https://www.3cx.com/docs/voicemail-transcription/
VM's are not being transcribed. I believe this original worked and it has just come to my attention that it is no longer working.
What log files would I review to try to determine a root cause?
We are running
ProductEnterprise Annual
Version Number16.0.9
Disable IPv6 and see. Did you by any means filtered the API key by IP address? If so, IPV6 is your issue. It's common. I guess you could whitelist the V6 IP as well.
Ha - my director's credit card had expired! No issues once the CC was updated.
Thanks!
GP Concepts
