VOIP SOLCON (username problem)
wilco
VOIP SOLCON
I try to use for the first time this program, verry nice
but if i use my provider solcon i get(voip)
[CM113006] Registration of sip:[email protected] has failed; reason=Unauthorized
this reason is the the user name is wilcodejongh and not [email protected] can i disable that it don't use the @sip.solcon.nl
its takes mijn server name and ad it to my username?
sorry for my englishe
i can call outside en intern but cannot get called from the outside.
what can i try?
with wireshark i see the number that is calling me
but the caller hears a in use tone?
please help me
You can try to send wireshark capture along with PBX's logs of incoming call into my mail box :) arthur at 3cx dot com
solcon
did you install the routing in the right way?
Not automatically every outside call reaches your phone, unless you rout it right. Call yourself on that number and see what is happening
i forwarde port 5060 to my pbx
port forwarding
you should open lots of ports more for this. Read the Port Forwarding messages.
i change my router and open port 5060 udp and this is working now.
old router is a speedtouch
up to the next problem
Ahzaz
