W60B connected by SIP rings once then gives 487 error
holleman
When moved to the office the extension via fxs/dect works
[CM503003]: Call(C:9): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Cancelled/INVITE from x.x.x.x:60004
sorry connnected bij direct sip :)
external call to extension that is forwarded (DND) to external extention2
Internal not tested yet.....but considered the configuration i don't think it will change anything
Version standaard 16.0.8 ...I will upgrade this weekend :) Thought I'd allready done that
BTW: Hyper-V Debian
Thats the sollution. I allways assumed that it was installed by default...Or is that only in the windows version?
Not by default, you have to do it manually if you will use a Hyper-V host because there is a lot of time-drift there for some reason.
Is the problem solved entirely now?
Isaac415
