W70b Provision failed
Remy1927
I am a noob so bear with me. I am using a raspberrypi for my SBC. I have gotten everything to connect except the base station. It will not provision no matter what I try. I have downloaded the newest firmware, reset the base to factory settings multiple times but no luck provisioning. I followed all instructions to the T, but am I missing something? Is there a username and password I should be entering in the phone settings under the provisioning url given by 3cx? I noticed in other threads something to do with FSX?DECT but I have no idea where this setting is and no supporting documents on it.
can you give some more details, what FW release is used on DECT base, which 3CX document did you follow to install, where is you PBX ? local ? cloud? 3CX Cloud ?
Do you use SMB licence PBX ?
You shall proceed with the latest however you need to ensure that the device is able to contact the PBX through https.
Reactions: Charles_3CX
ourladyofguadalupeamarill
