Want to Verify Can Use Different Google Compute Buckets for 3CX Backup and Recordings
EddieW
Gold Partner
Hi, I just wanted to verify you can use 2 different Google Compute buckets, 1 for the 3CX backup and 1 for Recording archives. Each would have/use it's own JSON file. I know you configure the location for each and just want to make sure each can use it's own bucket/JSON file. Thanks...
You can create different folders under the Google buckets to separate the backups and archives.
Yes, I know that can be done, but we prefer to use separate buckets for this. Is this supported in 3CX?
It's one JSON file per instance, so no, this is not possible.
Yes you can. You need to use the same JSON key for both but you CAN choose a different bucket for recordings and backups. We do it often.
If it’s one json used for multiple buckets then yes, but not using different json files for each bucket, as per what EddieW is asking.
Kayla Norris
