Was Vultr quietly removed again?
SaraMarlar
Forum User
We noticed last night that Vultr is no longer listed when creating a new license or getting a config.
I've noticed this morning that the thread for Vultr is gone, and the setup guides no longer list Vultr as a private cloud platform anymore.
I have a ticket in with support and I called to ask about it, and they directed me to normal setup guide which in step 2 tells you to get the config from the partner portal, which is no longer possible.
We have 35 systems in Vultr and many more to come :(
You can use the ISO to install in Vultr if needed.
Reactions: CentrexJ
We always use the 3CX Marketplace ISO to build the VM In Vultr, but how do we get a config file to upload to the system from the partner portal if they don't list Vultr has an option anymore?
Hey @SaraMarlar
We've updated the self-hosted deployment module to make deploying 3CX a much simpler and streamlined process. This involved including the Hosting providers we found to be most compatible and reliable in conjunction with a 3CX system so we recommend using one of them.
If you still insist on using Vultr you can. The 3CX image in Vultr's marketplace is still available https://www.vultr.com/marketplace/apps/3cx
You may use the same configuration file generated for On Premise linux installations to deploy so simply:
1. Deploy the 3CX image v20 on Vultr
2. When you reach Step 2 of this guide https://www.3cx.com/docs/pbx-vultr-marketplace/
3. Access our Customer Portal, find your key, select install > On Premise > Linux and download the setupconfig.xml
4. Upload the setupconfig.xml to the PBX Installation wizard and you should be good to go.
Hey @SaraMarlar
Thank you
Reactions: jed and ChrisC_3CX
amazingbv
