- Joined
- Aug 15, 2017
- Messages
- 500
- Reaction score
- 57
Currently, if you enter https://fqdn.of.your.pbx/ you will automatically be sent to the login of the admin console. If you want the user login you have to enter https://fqdn.of.your.pbx/webclient
This is often a reason for trouble since people forget the correct link, oder make a typo. Or they even only enter the fqdn. Then they dont read, and then they do not understand why they cannot login (even might blacklist theirselves).
Is it possible to revert this so that the default login is the webclient, and to reach the admin console one has to enter a path after the fqdn?
An admin should be able to correctly do this, users not. They should have only to remember the fqdn.
