Welcome email issue
DrLloyd
Platinum Partner
I saw another thread where someone was having an issue with the welcome email- Mine is slightly different- new install- v 16- using the 3cx smtp- tests OK, but no joy when sending a customized welcome email. When I go look at the logs- I see the following:
2019/10/16 15:29:47.788|2540|0009|Excpt|System.ArgumentOutOfRangeException: Count cannot be less than zero.
Parameter name: count
at System.String.Remove(Int32 startIndex, Int32 count)
at TcxMail.MailTemplateSender.RemoveMarkedBlock(String content, String startMarker, String endMarker)
at _3cxSystemService.ExtSheduller.WelcomeEmailSender.SendWelcome(Extension ext)
at _3cxSystemService.ExtSheduller.WelcomeEmailSender.SendingProc()
What am I seeing?
Can you confirm first if you use the 3CX default template, does it get delivered as intended?
I had not saved the default template, but I copied and pasted from a known good install- and it worked! I guess there was something missing in the HTML? Ok... well, thank you for pointing me in that direction!
Yeah, probably something missing and breaks the HTML parsing I would think.
You can also retrieve the original from this parameter in the PBX:
MAILTEMPLATE_EXTWELCOME_DEFAULT
Whereas your custom one is stored here:
MAILTEMPLATE_EXTWELCOME_CUSTOM
Reactions: accentlogic
Wecare_ITA
