Welcome Email V16 UK
Rhys Haskell
Since V16 SP2 we now get a Get Started with 3CX guide attached to our welcome emails, can we remove or edit this as it is saying that the voicemail number is 999. In the UK 999 is the number for the emergency services and we have had an instances of a customer calling the emergency services meaning to call there voicemail.
Perhaps here in global settings / emails
11556
Did you change default voicemail number in your PBX ?
Yes the voicemail is set by default to 666 in the UK. 3CX have made a quick start PDF they now attach to all welcome emails and have clearly overlooked the difference between the US and UK voicemail numbers.
11557
So, sorry i don't know where to find the PDF file to modify, wait for better answers than mine
Hi Rhys,
Its located in 3CX\Data\Http\Guides
Please note this may be overwritten in newer PBX updates
Hi Rhys,
Is there a parameter so we can not include this as it is a lot of work every time we upgrade a system to go in a delete the file.
Not at the moment, you can move the PDFs in another folder if you wish to disable this for now
[email protected].
