Wich Extension is Forwarding
Roberto Neves
Hey guys,
Does anyone know how if there is any way to figure out if an incoming call is a forwarded call and wich extension forwarded?
Thanks in advance!
Are the calls first going to a DID extension? Is the DID name attached to the caller ID?
Yes, they're going first to a DID extension and then they are forwarded. But the DID name is not attached :( Would be that the only way?
If you don't already add names, you can try adding the extension number, as the name . You may have to enable the addition of DID names to caller ID..
Reactions: Roberto Neves
If oyu don't already add names, you can try adding the extension number, as the name . You may have to enable the addition of DID names to caller ID..
Did that, thank you, leejor.
So, this won't work for internal calls :(
I'll study a little more to try to display the extension who is forwarding for internal calls either.
[email protected].
