Windows installation fail.
sotrix
Windows prevents the installation (as administrator) of the version downloaded from the Italian partner panel Ver 18.0.7.final
The message is as follows: check user account.
Running app blocked by admin, Unknown author.
And it's impossible installs......
I test it on more windows 11 station...the problem is the same.
Ver 18.0.6...installs ok
Do you have some tips?
Icona di Verificata con community
Install 18.0.6 and update from the console?
What’s blocking it? If antivirus you can post in https://www.3cx.com/community/forums/security-alerts/ but it seems like some a/v solutions started blocking by file name or certificate after the March app compromise.
Robert Lee
