Wordpress v 6.4.2, 3cx v20 and LiveChat plugin v10. Icon gray&forbiden
GP1noMendez
Buen dia. Recién acabo de instalar el sistma y configurar un lifechat con las versiones indicadas en el título, pero el icno no aparece activo y al pasar el mause muestra prohibido.
la web https://www.360nity.com/site (directorio de instalación de WP) y asi es la URL que he configurado en lifechat, he probado sin poner /site pero sin resultado. También he leido sobre el tema del certificado SSL y parece correcto, aunque esta firmado por lets encrypt.
Gracias por adelantado.
Good day. I just installed the system and configured a lifechat with the versions indicated in the title, but the icon does not appear active and when I move the mouse it shows prohibited.
the website https://www.360nity.com/site (WP installation directory) and this is the URL that I have configured in lifechat, I have tried without putting /site but without result. I have also read about the SSL certificate issue and it seems correct, although it is signed by lets encrypt.
Thanks in advance.
SOLVED! To be clear:
1. https://domain.com No WWW, NO folders or /
2. If the site is installed in a folder, just type the domain nor the subfolder like... https://domain.com/site (just works without the /site)
i hope it helps
Finatra.us
