Solved Wrap-up time Call Queue not working
Mickel den Ouden
Since we have upgraded our NFR 3CX from version 18 to version 20 the wrap-up time in the call Queues is not respected anymore.
If a user hangs up a call he picked up from the queue the next call wil be offered from the same queue immediately while the wrap up time is 120 seconds
Version is 20 update 1 (build 731)
If for example change the time to 100 seconds and press Save, does this still occur?
I did lower it to 100 seconds and this works.
So at this time 100 will probably be the maximum.
Thank you very much
If you now revert to 120 does the issue occur?
So currently your issue is resolved correct?
Yes it is but this is strange behavior
But i am glad i know how to deal with it and i wil be convinced it wil be solved.
This means that the setting was not properly saved to the database causing this issue.
Changing values and save resolved it and i'm glad now is working as expected ;)
amazingbv
