Solved X3U Pro BLF Keys Will not program or update
JBG
I have several Fanvil X3U provisioned phones and they have not been an issue. Now when I try and provision a new X3U nothing will program in the BLF except the first position. I had always been able to provision the first 3 keys. I took a phone that was already provisioned with BLF 1 as a line key and BLF 2 as a line key. Factory reset it, provisioned as a new extension and only BLF 1 programmed. Has something changed lately?
  • 3CX Version, 18.0 (Build 965) Standard
  • Server OS, Debian 10
  • Is the 3CX Server Hosted and where? On-premises
  • IP Phone Make/Model/Firmware version, Fanvil X3U Pro version 2.4.7.4
  • Provisioning Method: Local
  • Trunk Provider or VoIP Gateway Make/Model, SIP-Trunk
I updated the firmware to the latest and am now on 2.4.7.5. After that I still had a problem end ended up removing the phone from the extension, factor resetting the phone, and then reassigning the phone back to the extension. After that I am able to adjust the BLF keys again with the new firmware.
Thank you
Reactions: JohnS_3CX
Diogo Maia
