Yealink CP960 Zoom Room Firmware Update
cedar818
Yealink's CP960 zoomroom latest firmware is 73.30.0.36 and the latest firmware from 3CX is 73.85.0.5. Does uupdating the firmware from the dashboard will remove the zoom room function?
Thank you.
Zoom say the functionality works with firmware 73.80.0.5 or later (emphasis mine) so you should be fine.
Firmware is pretty easy to upgrade and downgrade so just test if you are super concerned but as @Lee Cramman mentioned you should be good as-is.
Wecare_ITA
