Yealink Firmware Updates for Legacy Models
Pierre_3CX
Staff member
3CX Support
New firmware ensures compatibility with 3CX V20 Update 7.​
Yealink has finally released new firmware for several legacy and end-of-life (EOL) phone models. These updates address a security issue recently reported by the U.S. Cybersecurity and Infrastructure Security Agency (CISA), registered under ICSA-25-219-08. 3CX has verified intero...
Unfortunately, I can’t update the firmware. The server reports an Internet Server Error. When checking the firmware directory, it says the corresponding firmware could not be found, even though 3CX is already on the latest version.
no Download Link?
Reactions: loyer
no Download Link?
If you clean the browser cache, and reload the Phones page will it let you go ahead?
If not then may I suggest the following:
1. Admin Console > Phones > Options > Use Untested - Unsupported Firmware
2. When you press OK, this will wipe the firmware folders clean from your system.
3. Then, using the same procedure, switch back to 3CX Supported Firmware.
4. Now all you have to do is go to Updates from your Dashboard, and you will see all the available firmware ready to download.
5. Once downloaded, upgrade one of your Yealinks and confirm that it went through OK, then you can go ahead with the rest.
If you prefer direct download: https://www.3cx.com/docs/phone-firmwares/
I had the same issue as Poseidon Technik posted about and the procedure posted above by JohnS_3CX involving the switching firmware settings worked.
Same error here - on checking, (local windows server) c:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\s68o8tqmto0yae5\firmware_new\yealink, the rom files downloaded the previous day had vanished. My first guess was antivirus, I set an exclusion for the folder, deleted the firmware folder contents and restarted management and re-downloaded the files.
Next day, gone again.
I've gone through the steps above and options are set to 3cx supported firmware, automatic cleanup is unchecked.
I can work round it but curious as to what's happening.
the method above resolved my issue as well...thank you John. Saved the day.
Reactions: N_G and JohnS_3CX
imelda
