Yealink ringtone for Queue and Ring Group
Maurice Lefevere
Gold Partner
Been looking around on the internet for a closing answer but can't find it, so here i am :)
We've got some customers asking for different ringtones depending on were the caller is positioned.
We are serving a lot of GP's who are using Ring Groups for emergency calls.
For example:
CALLER1: is in the Queue (normal)
CALLER2: is in a Ring Group (emergency)
For a long time we are using DECT's for the emergency calls, but would like to stop with this.
Is it possible to have 2 different ringtones so that the assistant can recognize the priority when not directly looking at the display?.
so CALLER1 has ringtone A and CALLER2 has ringtone B.
BTW: It is a HOSTED environment, but for some stange reason i can't post anything there..
Kind Regards,
Maurice
Hi Maurice,
Go to your phones page and click the Options button on top.
Enable this option which allows you to pick different ringtones per queue:
Then you will need to edit each extension from the management console, and for each phone you now have this option for custom queue ringtones:
Click the blue button and set your ringtones:
Reprovision the phone now so it can apply the new settings, and call the different queues to hear what it will sound like.
amazingbv
