Yealink T54W IP Phone is constantly looping a firmware update
rmalek
New User
When I power it on via ethernet to the Internet slot at the back, it starts up, obtains IP address and shows the correct information and connection. 5-10 seconds later, it begins a firmware update, goes through all the initializing then back to the home page, only for it to happen all over again! This has been occurring on this phone for a few weeks now. Have attempted to factory reset it, doesn't seem to do the job properly since I only have a small window to initiate it. I tried holding the redial button before turning it on but it doesn't seem to work. Can I get any advice here? Thanks.
You can try and power it up without network to see if you can cancel the upgrade or reset the phone.
But the best advice I can offer is to contact Yealink and describe the issue.
They might have some useful information on their support site, and if not you can open a ticket with they so they can advise you on what to do next.
Reactions: MidiTélécom
Finatra.us
