Solved Yealink T58
Red_Russ
Hi @Red_Russ this was discussed in this forum:
Please check it out, If you already have the T58W and running the sp9 it will show you the template, otherwise get it from the post above and import the file in PBX —- advanced —- templates —- phones.
In the sp10 that currently is in Alpha the template was added back.
Reactions: KyriacosS_3CX
HaroonEtp
