Yealink Template Change Log?
mattlowe67
I see new templates for Yealink in 3CX but no new firmware. Is there a change log that exists for what changed?
If I have a custom template, will I need to re-create the custom template based on the new version of the Yealink template, or will my current one work? The only thing I've changed is added a DTMF BLF key
There's no change log for the phone templates. All you can do is diff them yourself.
As far as the custom template goes, seems pretty easy to figure out if your template will work or not. If it does, great, and if it doesn't recreate based off the new one which is recommended if you decide to go the custom template path.
Hi @mattlowe67
The above is good advice, you should compare them yourself and see.
We added new models recently to the templates but I cannot say for sure if anything else has changed compared to whatever specific revision you currently have.
use winmerge to compare file content, all differences are highlighted very easy software and free
Wecare_ITA
