Yealink W90B set up on Step 5 and 6
guzty
I am trying to set up Yealink W90B and I can't seem to find the same menu options from step 5 and 6 of the DECT Phones instructions.
https://www.3cx.com/sip-phones/yealink-dect-phones/
from step 5, I don't have “Settings” > “Auto Provision” > “Server URL” to be bale to put the provision URL.
I also don't see this section on my side after I put the DECT Manager's IP, is this the same IP for the web interface of the yealink W90B?
You need to switch to DM in order to get those options.
You need to have a pair: W90DM + W90B
We provision the W90DM, and you connect as many W90B to it as you want to act as its
There is no support for a standalone W90B because the B device acts only as the wireless antenna for the DM device. Normally you would deploy one DM, and a few B devices across your building. This is the intended purpose.
a single W90DM cannot be used?
since it has antennas built in, and the area I will be using it won't need more range then a single unit.
Correct. A DM unit is just a controller, not a base station. This is per Yealink. While it may have external antennas on it, it won't support being a base station and DM at the same time. I'm surprised your distributor let you purchase just the DM without a base, ours would reach out to warn customers who make that error.
Reactions: accentlogic
Correct, this is what vendor provide. You should check Yealink documentations as well for further clarification.
Finatra.us
