Zero Billing some calls
JaredK
We have a client using the Hotel management system for call costings, we also have some rules in place where if there is no one at reception, calls are forwarded to a mobile. Works fine, however the customer is reported that guest are being charged to their room for the call even though they dialled a local extension number.
Is there a way to zero rate call to some mobiles? Do I add a Call Cost and enter the full number and Rate it as 0?
Seems easy enough to test.
Hey @JaredK
That should work yes. Do note though that what you are adding is actually a prefix, meaning that, if anyone dials a number that starts with those exact same numbers but also has additional digits at the end, it will still use that rate for that call. I know this is very unlikely but thought that you should know.
jmarshall
