Route inbound calls dynamically based on Caller ID, DID and time of day.
This script allows you to redirect inbound calls based on specific criteria such as time of day, Caller ID or DID. It is activated when a call is received on a trunk and reroutes the call to a configured destination.
How to Set Up the Time-Based Call Routing Script
- Go to Admin Console > Integrations > Call Scripts.
- Add from Store and select “Time Based Call Routing.”
- Name the script for easy identification.
- Run this script upon receiving a call on a trunk.
- Select the trunk where inbound calls will be intercepted.
- By default the script comes with predefined hours which can be changed to your own by modifying/adding/removing values from the schedule.
- { DayOfWeek.Monday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24))
- The script also accepts calls from all DIDs/CallerIDs as the variables DIDs/Callers contain the * where they can be changed to contain specific DIDs and caller IDs.
- Change 801 in const string DestinationDN = "801"; with your selected destination.
Why Use This Script
- Time-Sensitive Routing: Automatically reroute calls to specific destinations based on your business hours.
- Caller-Specific Handling: Create unique routing rules for important Caller IDs or DIDs.
- Efficient Call Management: Reduce manual interventions by automating call routing for after-hours or specific criteria.
Example Script
DISCLAIMER! This script is for reference purposes only. For the latest version, download from the store.
Script: Intercept Inbound Calls
* Time Base Call Routing - Use code with caution!
* Calls will be intercepted and redirected to the specified DestinationDN during the following times:
* Monday to Sunday: 5:30 PM to 7:00 AM
* The current destination DN is set to "801" modify destination to any system extension or extension you want.
* INSTRUCTIONS
* - Configure Date & Time (Line 31)
* - Change the destination DN, and modify the value of the constant DestinationDN to any destination you want to route call (Line 26).
#nullable disable
using CallFlow;
using System;
using System.Threading;
using System.Threading.Tasks;
using TCX.Configuration;
using TCX.PBXAPI;
using System.Collections.Generic;
using System.Linq;
using CallFlow.CFD;
namespace interceptcall
public class InterceptInboundCall : ScriptBase
// The destination DN to which the call will be redirected
// Define a schedule for when calls should be intercepted
static readonly Schedule schedule = new Schedule(RuleHoursType.SpecificHours)
{ DayOfWeek.Monday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Monday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Tuesday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Tuesday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Wednesday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Wednesday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Thursday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Thursday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Friday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Friday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Saturday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Saturday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) },
{ DayOfWeek.Sunday, new Schedule.PeriodOfDay(TimeSpan.FromHours(17.5), TimeSpan.FromHours(24)) },
{ DayOfWeek.Sunday, new Schedule.PeriodOfDay(TimeSpan.FromHours(0), TimeSpan.FromHours(7)) }
public override async void Start()
// Handle calls as a detached task, catching all exceptions.
try
await Task.Run(async () =>
try
MyCall.Debug($"Script start delay: {DateTime.UtcNow - MyCall.LastChangeStatus}");
MyCall.Debug($"Incoming connection {MyCall} from {MyCall.Caller}");
bool intercepted = false;
var ps = MyCall.PS as PhoneSystem;
if (MyCall.Caller.DN is ExternalLine externalLine)
var DIDNumber = MyCall.Caller["inbound_did"];
var CallerID = MyCall.Caller.CallerID;
var currentTime = externalLine.Now(out var utc, out var timezone, out var groupmode);
// Intercept calls during the specified schedule
if (schedule.IsActiveTime(currentTime))
string[] DIDs = { "*" }; // Allow all DIDs
string[] Callers = { "*" }; // Allow all Callers
var destination_struct = new DestinationStruct(ps.GetDNByNumber(DestinationDN));
// Check if the call's DID and CallerID match the interception criteria
if ((DIDs.Contains(DIDNumber) || DIDs.Contains("*")) &&
(Callers.Contains(CallerID) || Callers.Contains("*")))
try
var result = await MyCall.RouteToAsync(destination_struct);
MyCall.Info($"{CallerID} -> {DIDNumber} has been redirected to {DestinationDN} ({result})");
intercepted = true;
catch (Exception ex)
MyCall.Info($"{CallerID} -> {DIDNumber}: interception failed. '{DestinationDN}' is not reachable: {ex}");
else
MyCall.Info($"{CallerID} -> {DIDNumber}@{currentTime}: Default CallerID/DID based routing will be applied");
MyCall.Return(intercepted);
MyCall.Error($"Script execution failed: {ex}");
MyCall.Return(false);
MyCall.Error($"Task execution failed: {ex}");
