3CX has found a great new MiniPC option for v15: The Shuttle NC02U
With the Shuttle NC02U you can put together a low cost, yet reliable appliance for smaller offices where no server is available. It will run a standard operating system (Debian 8 or the Debian for 3CX) and consume very little power. Depending on on your PBX requirements, it can support up to 16 or even 32 sim calls.
Why the Shuttle NC02U?
The shuttle is simply the most performant MiniPC we have seen for the price!
- It’s Multi Core - very performant and 3CX fully utilizes all cores.
- Has a real SSD drive
- Certified for all major markets
- Has Cooling fans to dissipate heat
- Can run Stock Debian 8 / Debian for 3CX
- Memory upgradable to 32 GB
- Price approximately 180-200 euros (end user price, reseller price is lower)
- Can accommodate 2 drives: 1 x SATA 6Gbps and 1 M.2 SSD
Where to buy
Pre Loaded with 3CX:
https://www.edox.com/Webshop/default.aspx
Other sources
https://www.shuttle.eu/en/where-to-buy/distributors
https://www.shuttle.eu/en/where-to-buy/etailer
https://www.amazon.com/Shuttle-Computer-System-Component-NC02U/dp/B01KVCUURE
How to install 3CX
Follow these links for information on how to install 3CX on the Shuttle NC02U:
Specs
| Device Name | Shuttle NC02U |
| CPU Type | Intel Celeron 3855UCPU |
| CPU Speed | 1.6 GHz |
| Number of CPU Cores | 2 |
| Memory | 2 GB RAM DDR3-L |
| Storage | 32GB NVMe PCIe SSD 1 M.2 SSD Slot for high speed additional storage |
| Communications | Gigabit Ethernet, WiFi, Bluetooth |
| Sound | Audio Out |
| USB Ports | 1 x USB 3, 1 x USB C Type (3.0), 2 x USB 2.0 |
| Supported OS | Linux, Android, Windows. Comes pre-installed with Debian 8 Jessie |
| Graphics / Display | 64MB (Min) shared memory for graphics chipset. HDMI Port , VGA Port, DisplayPort |
| Power Consumption | Power consumption in idle mode: 6.7~7.8 W, full load: 11.3 / 21.7 W (without/with graphics) (measured with 2x 4 GB DDR3L SO-DIMM, 120 GB 2.5" SSD, Windows 10-1607 64 bit) |
| Temperature: | Operating Temperature: 40° C Designed to operate across wider temperature ranges due to construction materials. Built in cooling system Built in Fan |
External Reviews
https://www.funkykit.com/reviews/barebones-systems/shuttle-xpc-nano-nc02u5-review/
https://www.eteknix.com/shuttle-announces-xpc-nano-nc02u-sff-systems/
http://www.madshrimps.be/articles/article/1000925/Shuttle-XPC-Nano-NC02U-Barebone-Review#axzz4VvTiJSdL
