- Joined
- Sep 11, 2023
- Messages
- 368
- Reaction score
- 47
I am often asked to change the ringtone for a particular call group. Currently from the phone settings menu 3cx allows you to change the default ringtone and the one for calls coming from queues. I carried out tests with wiresherk basically if the call is internal 3cx does not insert any alert-info if it is destined for a queue that is internal or external Aler-info=queue if the call is external Alert-indfo=external, at this point yes can differentiate calls between phones with a customized template
internal no alert-info default ringtone
external alert-info external
coming from an alert-inf queue
There is no way to customize the Alert-Info
It is often requested to differentiate the sound for example of a interphone or a particular coda, called international
There is no system?
There is no system?
