3cx audio converter
rbergthold
I've always used the 3cx audio converter; but recently it's been converting the files that sound crisp & clear into static files where the speaker almost sounds as if they have a lisp.
Is your source not registred too high level decibel generating some distorsion?
Why not just use Audacity ?
Here you will have full controll.
Paulo
Reactions: CentrexJ and RoryJ
What are you using to generate the file in the first place?
I know I had this issue when creating audio files with AWS Polly. Once I started changing the bit rate to 8 kHz (which was not the default) it solved my issues.
I recommend using Audacity. You just import the audio file, then simply go to export it with your required parameters.
Reactions: CentrexJ and ivank
Another vote for Audacity. The tool is free and works perfectly.
Reactions: CentrexJ
Also with Audacity you can convert multiple files all at once. Huge time saver when converting multiple files.
i will use audacity. but before they made the change on the audio converter, i was able to run about anything through there and it came out great. Also, there were fewer steps involved.
georgi
