- Joined
- Sep 20, 2018
- Messages
- 6
- Reaction score
- 1
3cx extension works fine on any windows PC with the 3cx extension installed. However when using the same Google account on my Samsung 303c (older chromebook) the extension is unable to connect to the webclient/browser even after getting all the correct prompts such as linking to extension and allowing microphone. I would suggest that perhaps my chromebook is the problem as it is quite old now, although is running the latest updates. See the screenshot for the error.
Has anyone managed to get the webclient/3cx extension to work on a Chromebook at all, even if it a newer Chromebook device - this would be helpful to know?
Thank you
M
Thank you
M
