3CX desktop App config file iOSapp Androidapp
Two-iT
After changing a user account Password and Auth ID,
I would aspect the Windows Desktop App AND iPhone App AND Android App won't be able to connect with previous conifg FILE.
I'm very stunned that after copying the config file to a new iPhone (with old Auth ID and Old Password) I'm sitll able to connect.
The new Auth ID and Password get pushed to the iPhone thats @@!##
The only way to reset a ID (user) is to compelety delete the user?
If you would have 15 general users connected to call flow apps then you have to review the call flow app as wel. (when deleting a user)
Normal would be, when resetting a password of auth ID NO client can connect and you have to resend the welcome email.
(did try this on 2 PXB servers both the same problem)
Can some one veriefy this.
(dutch sorry for enligsh)
Use the Regenerate function to change the apps provisioning ID to prevent that.
Thanx for the reply.
Only remak why not alert about this when resetting password. Maybe missed out on training.
NathanMitchell
