3CX Direct Routing Outbound Calls Fails
Buny38
New User
Hello Everyone im from Germany,
i have configured the Direct Routing in my 3cx according to instructions from 3cx.
Icoming Calls to my Number can i see and use in my Teams.
If i want to call outbound from teams, this fails after 3-4 seconds.
In the 3cx reports is the failure: 04.08.2022 10:32:09 - [Flow] Target endpoint for +4915779657858 can not be built!
I need Help for this Problem
Check that there is an outbound rule to accommodate the number you are dealing, in addition to disabling the E164 options under the management console > Settings > E164. Not remove the + or +49 depending on what you have configured there.
Tip: Remove the DID number from your forum post if it is a real number.
i Have a Standard Outbound Rule in 3cx.I can call from 3cx to outbound.
05.08.2022 10:44:50 - [CM505001]: Endpoint Extn:12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [] PBX contact: .........................
05.08.2022 10:44:50 - [Flow] Target endpoint for +4921xxxxxxxxxxxxxxcan not be built!
05.08.2022 10:44:50 - Call(C:31): from Extn:12 to +49xxxxxxxxxxx doesn't match any outbound rule. No outbound rule could be selected.
05.08.2022 10:44:50 - [CM503014]: Call(C:31): No known route from Extn:12 to target: <sip:[email protected]:5062/UDP>
05.08.2022 10:44:50 - [CM503016]: Call(C:31): Attempt to reach <sip:[email protected]:5062> from Extn:12 has failed. Reason: Not Found
05.08.2022 10:44:50 - [CM503020]: Call(C:31): Normal call termination. Call originator: Extn:12. Reason: Not found
05.08.2022 10:44:50 - Call(C:31) is terminated
As per your snip-it, this is due to the following and as I have mentioned in my previous reply.
How can i add a outbound rule for my number.
I can call from my 3cx app. I have there configured outbound rules already.
You need to check if there is an outbound rule that can process calls from +49 and disable the E164 processing from under the management console >settings> E164 proccing section.
Okey the Problem is solved.
I have created a outbound rule for +49 numbers.
Thanks for the fast Answer
Reactions: Charles_3CX
You are welcome.
KylieWilderman
