3CX Is Unable to Find Suitable Network Adapter (Activation Failed)
TeldataSolutions
Platinum Partner
After upgrading from V15 to V16, I'm getting an Activation Failed error with the following message: "3CX is unable to find a suitable network adapter on this server. Check that you have an enabled network adapter and that it is connected to the internet so 3CX will be able to reach 3CX activation servers and activate your license."
There is only one network adapter active on the system. The nameservers set for the adapter are 8.8.8.8 and 8.8.4.4
An nslookup on activation.3cx.com returns:
Non-authoritative answer:
Address: 151.80.125.88
System Information:
  • 3CX Version, Pro Annual 16.0.5.389
  • Server OS, Windows 7 Pro
  • On-Premise
Ver 16 is not supported on win7, has to be win 10
I understand that, however, I have many other installs with Windows 7 and V16 installed.
Reactions: craigreilly
