3cx raspberry pi 4 - call recordings
DjordjeV
I have 3cx installed on pi 4 with 32 GB microSD storage and i need some additinoal storage for call recordings. Is it possible to archive or store them on local server drive via network, if not what is the best solution , external hard drive, does it work with pi4?
There is an option to archive your call recordings. To check the options and set up remote archiving, log in to the Management Console >> Recordings >> Click Location >> Enable Remote Archiving.
You can select where you'd like to upload your call recordings to, and how often so you have the flexibility to run it during your out of office hours.
Do You know can I arhive them on Windows server FTP ? Should it work?
The options for archiving recordings are ftp, smb , sftp and google storage.
So to answer your question, yes you can use ftp
Reactions: NickD_3CX
kevlaboom
