Solved 3CX v15.5 - Record call not working
ANJOTI
we are unable to record a call press the button 'record' on the Windows client or on the Android client; the extension already have permission as bellow:
- Extension properties / Phone Provisioning / Access
- Show call Recordings
- Allow Deletion of Recordings
Is there some other option to enable and accomplish the recording?
* The recording QUOTA is 5GB as default
* We realize that record button cannot go to 'blue color' as this example: http://blog.ipphone-warehouse.com/how-record-call-3cx/
Usefull links but no success:
- https://www.3cx.com/community/threads/record-calls.54709/#post-225503
- https://www.3cx.com/community/threads/3cx-recording-access-permissions.54690/
- https://www.3cx.com/community/threads/call-recording-rights.55564/#post-230117
On the extension >> Options you have "record all calls" but I am not sure if this will suit your requirements as it will record all calls from start to finish without any need to manual intervention.
Even set up it, user cannot see any records...
Call record is available to all Editions...
Let me try to increase QUOTA...
Even increasing the quota, no sucess.
After checking the system 'parameters':
  • CALLRECORDSROOT Define the root path of call recordings = /var/lib/3cxpbx/Instance1/Data/Recordings
  • DELETE_RECS_OLDER_THEN Delete recordings older then this amount of days = 30
Using SSH connection, that Path is valid but without files there
folder permissions:
Code:
root@instance-1:/var/lib/3cxpbx/Instance1/Data/Recordings# ls -ld
drwxr-xr-x 2 phonesystem phonesystem 4096 Feb 23 07:38 .
Where are you seeing this ? In the 3CX Interface just go to "Recordings".
You can set your Quota here without issue, you should not need to go into your Linux OS at all.
Even using 'Recordings' options and change quota from 5Gb to 6GB, no sucess...
* I was just reviewing system settings and validating path.
Is there some 3CX employee to help on "how to troubleshoot" that case?
Hello @ANJOTI
First try re-activating the licence of the PBX. To do so please navigate to Settings / Licence and click on "Refresh licence Key Information". Then try a call again and let me know if that works. If that does not work then you will need to have a look at the PBX logs after you enable verbose logging.
Reactions: Joonwon Kim
Hi @YiannisH_3CX ,
after "Refresh licence Key Information" now the record call feature is working! Tks a lot!
Glad to see the issue has been resolved and thank you for updating the thread with the solution
