3cx v16 Cannot view the 3cx console from the local IP: 403 Forbidden (nginx)
gtsystems
I am trying to fix a weird provisioning issue, I have some Yealink T41P phone, when i put them on the network after a factory reset then going on the on the console via the FQDN page, I see the phone listed, I then select the phone and then provision, nothing happens, I then go into the phone UI and manually entering the non secure (hhtp) provisioning address and try try a force provisioning, still nothing, I then enter the secure address (https) with a port of 5001, then the phone provision normally, I then see on the 3CX console it's registered ok, I then select to update the firmware and nothing, I log back into the phones UI and check the provisioning url and it's reverted back to the non secure (http) address, I tried to view the address on a computer on the same local lan and a message 403 Forbidden nginx, this does not happen on other installs and feel this is cause of the issue, the phone has no access to the folder
As above, please check that link and provide us with full feedback on your installation so we can better understand the situation
Hi there, yes this is a new install
Not on the blacklist and has the latest firmware on it
Tried the phone on an another setup and it works fine
[email protected].
